Quote:
Yeah I'd go through it carefully... Change fluids, check spark plugs, cap, rotor, fuel pressure, fuel filter, etc... Make sure all the basics are in order so you know what you have.Originally Posted by jeremyhurt82
I just picked up a 1990 Trans Am GTA 5.7 automatic that's been sitting since 2006. Got it home yesterday and washed it. Guess I'll start by swapping all fluids and filters and see if she will run. If it's bone stock, there's really not much to do on the tune unfortunately.
If you're planning on engine modifications, then more likely you'll want to get some tuning done for optimization depending on what you do.
my car gained massive torque from a tune over stock. Originally Posted by ULTM8Z
Yeah I'd go through it carefully... Change fluids, check spark plugs, cap, rotor, fuel pressure, fuel filter, etc... Make sure all the basics are in order so you know what you have.If it's bone stock, there's really not much to do on the tune unfortunately.
Updated first post with current links.
