Cannot get chip to burn.
Old Mar 31, 2016 | 11:30 AM
  #51
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Cannot get chip to burn.
Originally Posted by RBob
Bulb could be removed.... Module may not be sending the signal to the ECM....
RBob.
I'd be curious to see if the starter relay behind the drivers kick panel was jumped, because it is odd that she cranks and fires with the stock memcal, but still cranks but with no fire with the adapter, memcal and chip...
Old Mar 31, 2016 | 01:03 PM
  #52
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
The stock memcal does not have the aujp sticker on it. Maybe they disabled the vats then. That's why they had a yellow wire running directly to the starter and it starts with a switch not the ignition. I'll try to disable the vats. What should I be looking good for? A flag or just disable everything to do with the vats system?
Old Mar 31, 2016 | 05:47 PM
  #53
Engine: 350 tpi
This is all I found on the bin that has to do with vats. And none of them have been set? Is there something good else I should be looking for to delete the vats?
Old Mar 31, 2016 | 06:19 PM
  #54
Engine: 350 tpi
Bingo!!! that was it is disabled the vats and she fires right up!! Awesome thanks guys I appreciate all the help. Sorry for asking so many questions, and frustrating ppl. Now to delete the air system in the bin. Thanks again
Old Mar 31, 2016 | 06:27 PM
  #55
Engine: 350 tpi
What would be some stuff I could change to help the car run a little better? Or I have to datalog first and see how it's running in there?
Old Mar 31, 2016 | 08:08 PM
  #56
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Congrats! Finally!
You can alter knock attack and recovery rates.
You can add a tiny bit of timing if you're using higher octane fuel.
Old Apr 1, 2016 | 10:15 AM
  #57
Engine: 350 tpi
Ok awesome. How would I go about deleting the air system? Does it rrally make a difference
hotrodjames
Mar 17, 2016 01:50 AM
DynoDave43
Car Audio
Mar 9, 2016 02:53 PM
bryanwood74
Mar 9, 2016 09:34 AM
ray jr
Mar 5, 2016 12:22 PM
Clint's 86
Mar 5, 2016 11:56 AM
