Is there more things to do to disabel vat ,egr and canister system. don't need this
Edit Log for JET STAGE2 90-92 L98 auto 730 $8d - Kopia.BIN created by TunerPro.
06/01/2016 01:53:37 Flag: VATS Select changed from Set to Not Set..
06/01/2016 01:55:40 Scalar: EGR %TPS Disable Threshold changed from 1.95 % TPS (0x05) to 0.00 % TPS (0x00).
06/01/2016 01:55:51 Scalar: EGR %TPS Enable Threshold changed from 2.34 % TPS (0x06) to 0.00 % TPS (0x00).
06/01/2016 01:59:16 Scalar: Minimum MAT for EGR Enable changed from 30.00 Counts (0x1E) to 255.00 Counts (0xFF).
06/01/2016 02:00:07 Scalar: Min Canister Purge Duty Cycle (Low TPS) changed from 50.00 % (0x80) to 0.00 % (0x00).
06/01/2016 02:02:43 Scalar: Canister Purge - Vehicle Speed Enable changed from 1.88 MPH (0x06) to 0.00 MPH (0x00).
06/01/2016 02:03:20 Scalar: Canister Purge - TPS Enable changed from 1.56 %TPS (0x04) to 0.00 %TPS (0x00).
06/01/2016 02:03:41 Scalar: Canister Purge - Vehicle Speed Disable changed from 0.94 MPH (0x03) to 0.00 MPH (0x00).
06/01/2016 02:04:06 Scalar: Canister Purge - TPS Disable changed from 0.78 %TPS (0x02) to 0.00 %TPS (0x00).
06/01/2016 02:06:26 Scalar: EGR Diagnostic Minimum Vehicle Speed changed from 30.00 MPH (0x1E) to 255.00 MPH (0xFF).
06/01/2016 02:08:21 Flag: VATS Diagnostic (Error 46) changed from Set to Not Set..
06/01/2016 02:08:39 Flag: Cansiter Purge when Output Energized changed from Set to Not Set..
Car: check
Engine: check
Transmission: check
Re: Is there more things to do to disabel vat ,egr and canister system. don't need th
Sure, but you are so far off course I didn't want to be the one to tell you. From what I can tell these two changes are the only correct ones:
With using the MAT to disable EGR there is no reason to change the TPS% trip points.
This flag is used to select the type of CCP solenoid, either NO or NC:
Changing it will cause purge to be on when it should be off, and vice-verse.
Making these changes will allow CCP to occur at idle and decel:
Note that we also highly recommend starting with a clean non-altered stock GM BIN.
RBob.
RBob.
327_TPI_77_Maro
Apr 24, 2006 01:08 PM
