Some verification please
Old Jun 12, 2016 | 03:28 AM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
So, I've downloaded Tuner Pro RT and acquired an ALDL to usb cable with 160 baud TPI, and 160 baud carb/throttle body options, 10k resistor option and 8192 rate.
I have acquired the correct Bin file, ADS file to ADX file, and ADF file. However, my program, which is running Windows 10, cannot recognize the ALDL cable when I try and configure under Preferences. The computer itself accepts the cable and downloaded it flawlessly without the use of extra driver software. But Tuner pro gives me the same message "checked at 8192 baud rate, cable is connected or not functioning, please disconnect cable from vehicle" (not exact, I don't have it in front of me, but close)
Anyway, my question is, for my vehicle (stats on left are correct- TPI), what should I have the connector set to?
I got the files from Tuner Pros website, the masks were $6. However, the BIN file I questioned due to 3 possible unmarked picks. (But it shouldn't matter anyway, until later).
Old Jun 12, 2016 | 07:17 AM
357L98's Avatar
Re: Some verification please
I had a similar problem. I found that Tunerpro will not detect the com port you have the ALDL cable connected to, you have to tell it which one you want to use.
Old Jun 12, 2016 | 08:15 AM
killer777's Avatar
Engine: 355
Ah, I failed to mention that. I had the computer recognize the cable in COM3 on my labtop, and set tuner pros settings to COM3.
Old Jun 12, 2016 | 09:11 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Your 89 has a 165 ECM which is notorious for communication problems, quirky at best. You need to switch the 10K resistor into the circuit to start the communications with the 165 then, when communication starts, switch the 10K resistor out of the circuit so the ECM does not stay in diagnostic mode and resumes normal function. HTH!
Old Jun 12, 2016 | 09:53 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
When you are detecting the cable in Tuner Pro, is it only connected to the computer and not the vehicle at the other end? It needs to be connected to ONLY the computer to be correctly detected.
Old Jun 13, 2016 | 09:59 PM
killer777's Avatar
Engine: 355
Good information to know.
Yes, only the connector is connected to the computer, unplugged from the vehicle.
I'm running windows 10.
Also, i have tried all 3 ports on my labtop, disregarding it suggesting port 3. (I still tried port 3 to no avail.)
Downloaded a different ADX. file, although, this did not help.
Connector was set for my specific vehicle.
Old Jun 14, 2016 | 06:06 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
You have to go to device manager and set the com port number for the cable (you will see it change and add an item when you plug the cable in. Right click on that new item drill down to the port setting & change to the com # you want to use)
Old Jun 14, 2016 | 07:41 AM
killer777's Avatar
Engine: 355
Maybe these will help. I feel as though I have everything set up correctly.
Old Jun 22, 2016 | 01:51 PM
killer777's Avatar
Engine: 355
I got the cable to read and began datalogging. Now, for programming. Chip burner or emulator. If i get the ostrich from moates, and i have the aldl to usb cable, is that all I will need? How does the emulator connect to the vehicle?
Abubaca
Dec 16, 2020 01:02 PM
tecboy
Interior Parts Wanted
Apr 2, 2016 08:17 AM
86IROC112
Mar 26, 2016 04:38 PM
iiAmDomo
Aftermarket Product Review
Mar 24, 2016 02:27 AM
RamIt
Alternative Port EFI Intakes
Mar 20, 2016 10:25 AM
