EBL Flash Questions: '95 Yukon Supercharged MPFI
Old Apr 14, 2017 | 11:00 PM
GMCYukonDriver's Avatar
Hey guys, so this is going to be a bit of an extensive post, but as such, I'll do my best to organize it. Here's the setup I'm running right now. I've got a 1995 GMC Yukon with ECM 16197427. I have a custom tune from Wester's garage to run the 4L80e I swapped in place of my stock 4L60e (wires were re-pinned so that the connector at the ECM is the same as a stock 4L80e truck). I'm also running an older (autorotor) style Whipple supercharger. I have the larger pulley on it for now, so it's making minimal boost. I have an Aeromotive AFPR set to handle fuel pressure (boost regulated), and I'm running 91 octane with plugs that are 1 heat range cooler to prevent detonation. Motor's got 216k on the clock, unrebuilt.
On to my plan. Eventually, I'd like to rebuild the motor to be a full hydraulic roller with some better heads (probably iron eagles). I also have an Edelbrock MPFI intake that I really want to get put on this thing, better fueling and able to tune it more precisely. Probably going to go with some Magnetti Marelli Pico injectiors, still working on which ones. So I have the following questions:
1. From what I've read, the current EBL Flash does not support the e-trans. Is this right? Is this possibly going to change anytime soon, or do you still have to run 2 separate ECM's?
2. Also, I have a lifetime re-tune with Wester's, and as long as the trans tables stay the same, then the engine control portion would be able to be burned from my PC via ALDL cable, correct? The Memcal would control the trans, but wouldn't need to be removed for tuning of the engine?
3. These TBI injectors are low impedance "peak-and-hold" style, correct? And according to your site, I would be able to run high-impedance injectors, but would you recommend the Port Mod or the 4-injector upgrade? Seems like the Port mod would be better since I'm looking at batch fire of 8 high-impedance injectors.
I appreciate any help you guys can give me. I've tried to do as much research on my own as I can, but sometime you just gotta ask a question (or three ). I'm sure I'll have more questions later. This seems to be my best option for controlling the motor with this MPFI intake. I have almost no knowledge of doing my own tuning. It's something I'd love to play around with, but just haven't had the time to research so far. Maybe once school finishes in a couple weeks. I'm more than willing to learn, and any resources you guys can point me to would be great. I'm definitely going to work my way through the "Tuning Guide" sticky up top.
And yes, before anyone asks, I DO realize an LS-swap would've been cheaper and easier. I like to be different, ok?
Old Apr 15, 2017 | 12:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Flash Questions: '95 Yukon Supercharged MPFI
Correct, the EBL Flash won't support the E transmission. Need to retain it for that job and add in the EBL Flash to run the engine.
Not sure what you are asking here. The EBL systems have their own firmware and calibration layout. Can't use the one from the '7427 PCM. There is a dedicated high speed comm link from the EBL to the laptop for flashing in the tune/BIN, data logging, and observing the data.
You will want the Port Mod when using the Edelbrock MPFI conversion. Note that with the Port Mod you can run any high impedance injector, don't need to stick with the Magnetti Marelli Pico injectors.
Note that an EBL Flash ECM with the Port Mod can not be used with a TBI setup.
RBob.
Old Apr 15, 2017 | 01:38 PM
Thanks for the reply, Bob.
So if I'm understanding correct, my '7427 ECM stays in place, just to control the trans. The EBL Flash gets spliced in, so is it an entirely separate ECM that I need to stack on top of my stock one?
I guess my second question was asking if there is any need to modify the chip in my 7427 to control the trans, since it won't be receiving any input from the engine? Or is it just a matter of installing the EBL ECM and the trans will still run as normal?
Your last comment about not being able to run a TBI engine, so I would basically need to do the EBL Flash port mod at the same time as the MPFI intake, and I should be good to go, but wouldn't be able to go back to Throttle Body injectors, correct?
Like I said, I know I'm going to have a few questions. I'm willing to be patient, and take time to learn, but it's a lot of stuff to take in.
Old Apr 15, 2017 | 11:36 PM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
Your 427 computer will still be receiving sensor data from the engine just as it does now, it just wont be able to control the fuel or ignition.
Old Apr 16, 2017 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes.
As The_Punisher454 mentioned the '7427 PCM still gets the sensor inputs that it requires to run the transmission. They also go to the EBL Flash ECM for it to use (shared). If you want a knock reporting setup you will need to add in an external knock filter. With the 4L80E the loss of the knock sensor to the '7427 PCM causes the shifts to be funny. Using a 3.9K ohm resistor in place of the knock sensor fixes this.
That is correct.
RBob.
Old Apr 16, 2017 | 02:32 PM
Dang, didnt know that one, I'll keep that in mind.
Old Apr 16, 2017 | 04:11 PM
Is there a reason that the knock sensor wouldn't be able to be shared with both the EBL Flash and the 7427 ECM?
Bob, I also read another post you made in a different thread stating that the EBL Flash did not support boost? What did you mean by that?
Again, thanks for all the help, guys. I have 1 more week of classes, then I'll be diving into the tuning aspect as much as I can. Can't wait to get started with this intake. Right now, I'm averaging 9-10 mpg. I know it's running rich, but from what I've read about the throttle body injectors, they have to be rich at idle and low RPM in order to keep up with fueling needs at higher RPM. The kinds of injectors and tuning that I can do with this MPFI setup would greatly improve that aspect.
Old Apr 17, 2017 | 08:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Try it and see how it is. It may attenuate the knock sensor signal some, but that can at times be a good thing.
Without the context that statement was made, I don't know why I would post that.
The EBL Flash ECMs can handle a 2-bar MAP (to 15 psi boost) or a 3-bar MAP (good to 30 psi).
RBob.
Old Apr 17, 2017 | 09:46 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Maybe he searched an old thread about Classic EBL, and just assumed EBL Flash. Dunno...
GMCYukonDriver, you dare flaunt a Whipple Supercharger with no pictures for us...?
Old Apr 30, 2017 | 12:39 PM
Thanks for the help guys. I'm sure I'll have more later. Now I'm off to go read as much on tuning with EBL as I can. I'll come back with more questions, I'm sure.
Just a couple parting questions. Would running EBL Flash interfere with a code reader? For example, if I have an issue, would a mechanic with a reader still be able to diagnose it?
Second, would this affect smog testing at all?
Old Apr 30, 2017 | 12:43 PM
Lol, here ya go Street Lethal. That pic is back from when I first installed it. I've done some minor work since then. Mostly working on a custom CAI tubing setup (not much room between the throttle body and the firewall). Going to build a box for the filter so it seals up to the fender. I wish I could figure out how to take advantage of the cowl hood with ducting to the filter or something, but I'm just not sure if I have the clearance.
Old May 1, 2017 | 01:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The MIL lamp gets moved over to the EBL Flash ECM. But the ALDL data stream is still from the PCM. So yes, the PCM can still be scanned.
Not unless the tune was totally hosed. The EGR is supported along with a CCP purge valve (if used).
RBob.
Old May 23, 2017 | 12:28 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm.. What blower is this? What manifold?
Vortec Distributor ?
I've not seen this setup before for an SBC.
-- Joe
