Bosch 3 150943 Injector Offsets
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Anyone have BATT V offsets for these injectors? They are rated at 21# for 42psi
Yellow tops look to be Mustang injectors.
RBob made a comment in another thread that the Bosch 3 injectors flow more at smaller PW than at larger, so suggested "zeroing out" small PW compensation. Would that be true for these injectors as well?
Car: check
Engine: check
Transmission: check
Re: Bosch 3 150943 Injector Offsets
That number should be a type 1 Bosch injector. Stan Weiss has them at 18.25#/hr at 43 psi. Used in the smaller engines such as the 3.8l 6-cylinder and 4.6l 8-cylinder engines.
I don't have any other information on them.
RBob.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Thanks RBob. So they are over 15% smaller than what is called for in the cal assuming fuel pressure is 43.5psi. Sounds like I would need to adjust for that in the cal. I’ll confirm fp first however. May be ok w higher presure.
