VE Offset. 1 byte or 2
Old Jan 30, 2018 | 02:33 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
The LT5 has 4 VE tables w 4 corresponding Offset constants. I have run into an issue where one copy of the .xdf uses 1 byte, while another uses 2. So I can use the 2 .xdfs, with 2 different addresses (one being -1 of the other) and read the same bin correctly. Can someone answer if the VE Offset is a 1 or 2 byte
item? I imagine GM handled it the same way for other masks. This is true for all the LT5 masks.
A sample of this:
$D0A 9B3 and 9B4
BPPA is stock bin
Old Jan 30, 2018 | 03:00 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: VE Offset. 1 byte or 2
Is there a documented disassembly out there? It's easy to check off that.
Old Jan 30, 2018 | 03:07 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I do not have one. Its odd because there are several .xdfs for it, and some use
1 byte while others use 2.
Old Jan 30, 2018 | 03:38 PM
Engine: LB9
Axle/Gears: 3.08
If you can find one from a similar year you can use it to quickly reverse engineer the correct one and find out what’s actually being pulled by the subroutine when it’s time.
Old Jan 30, 2018 | 03:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The offset is a 2 byte value. The reason it looks OK with the wrong XDF is that the calibrations I've looked at, GM uses the decimal value of 100 for the offset (39%). As long as the offset is lower then 256 it all fits into the LSB.
RBob.
Old Jan 30, 2018 | 04:02 PM
Engine: LB9
Axle/Gears: 3.08
RBob.
This is the assumption I had made, I guess my brain still works.
Old Jan 30, 2018 | 06:35 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
RBob.
Thanks RBob. As usual always very helpful. I think some of the earlier .xdfs had used the 1 byte but later ones correctly use the 2byte.
MonteCarSlow
34
Aug 16, 2009 08:27 AM
dpmalibu
Jul 3, 2008 05:57 PM
327_TPI_77_Maro
Feb 25, 2005 07:57 PM
Doward
Nov 5, 2004 12:09 AM
anesthes
Apr 14, 2004 02:22 PM
