tunerpro rt datalogging windows
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
how do you set these up so when im datalogging I can see what the hell is going on. I have the proper adx file but my histogram window is blank. I was informed that I need to edit the adx file to start brining up the window parameters so I can see whats going on.... im new to this and this seems to be a pain in the bum. if anyone can give me a step by step on how to set this stuff up that would be great..
I got it to were I can datalog but cant see any info because I have no maps.... I hope I explained what I need help with correctly.
thanks all.
thanks all.
Re: tunerpro rt datalogging windows
thanks all.
thanks all.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
to view data load the adx.
click on the data monitor icon at the top of the screen or data view list.
Once you click on the data monitor and it comes up you can customize it bye left clicking
and the viewable items list will show.
Click on the desired items you want to see while the catalog gets played back.
to build a histogram
load the adx.
click on acquisition
edit definition
click on history tables
add new item
enter in the name description and desired output.
then fill out the y and x axis.
click save and your ready to use your newly added history table.
load the adx.
edit definition
add new item
Engine: Lb9
Transmission: M20
thank you for this.
