need help choosing eprom
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: need help choosing eprom
Originally posted by wuter
can i use a 27c256 in a car with the 165 ecm? the chip i have now is a 27c128 but i dont want to mess that one up.
thank you
thank you
https://www.thirdgen.org/techbb2/sho...ghlight=27c256
The message is the thread from Glenn91L98GTA
And then, this thread.
https://www.thirdgen.org/techbb2/sho...threadid=39297
Always keep a good/known to work MEMCAL. Things do go wrong sometimes.
Also, do a search on 27c256 and you will find more information than you can think of questions to ask.
Car: Death Mobile
Engine: 666 c.i.
Yes, you can use a 27C256 on a 165, but you must "offset" the BIN to load on the top half since a 256 is a 32K chip and a 128 is a 16K chip.
But, why use a 27C256 when you can use an AT29C256 Flash Prom. The only downside to using Flash Proms is that your UV Eraser collects dust.
