32# Accel injector tuning
Old 01-17-2019, 11:04 PM
Boosted tpi's Avatar
Hello my name is Aaron I have a 1987 Pontiac Firebird Trans Am GTA 5.7 TPI fresh rebuild. I'm switching to Accel 32# injectors 12volt high impedance P/N 150132. I'm needing the offset compensation values, & if all possible the short pulse width compensation data aka minimum PW, and excellent advice on what I should do in the VE tables? The modifications in & on my engine are hooker shorty headers, hooker Y pipe, no catalytic converters, exhaust flows pretty decent, bored .030 pistons very little change in compression, Resurfaced heads 10 thousandths of an inch, & block decked 10 thousandths of an inch as well I think it may be around 10:0:1 compression ratio now, other than that just a MSD blaster coil, 8.5 mm plug wires, and a cold air intake. I have installed the EBL Flash ECM and is converted to a MAP sensor, & I'm using Tuner Pro software. if anyone has any great advice, data, or info it would be greatly appreciated. Please let me know and thanks
Old 01-18-2019, 11:37 AM
GeneralDisorder's Avatar
Re: 32# Accel injector tuning
I would call Accel if you didn't get the offsets with the injectors. That's the #1 criterion for buying injectors - no offsets? NO sale.
GD
Old 01-18-2019, 01:47 PM
ULTM8Z's Avatar
Yep... if those offsets aren't right you could very well be chasing your tail on trying to get BLM's and AFR's dialed in.
Old 01-18-2019, 08:40 PM
I got off my dad he's had them laying around for a while.
Old 01-18-2019, 08:44 PM
I've found a few offsets sheets online, and in threads but not sure how correct they are, and could it be true 30#-whatever size would use the same offsets?
Old 01-18-2019, 10:32 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Amen to that.
Old 01-18-2019, 11:00 PM
ULTM8Z's Avatar
not in my experience. I've tuned several cars over the last few years since I took notice of the impact of injector offsets, and it needs to be right in order to get the best results.
Old 01-18-2019, 11:05 PM
P/N 150132
Old 01-18-2019, 11:16 PM
ULTM8Z's Avatar
I found this while perusing Holleys website...
https://www.holley.com/products/fuel_systems/fuel_injection/injectors/parts/150832
look in the tech resources section to
toward the bottom to find the datasheet.
not exactly the same P/N, but if they use similar internal electronics, it may be close enough. note that the data sheet is for three different injector p/n's. I've done a couple of cars with Bosch-IIIs where I used a different Bosch-III offsets and it evident was close enough as I got them tuned adequately.
Old 01-18-2019, 11:25 PM
https://www.holley.com/products/fuel...s/parts/150832
I found that as well and have been going off of that with the start of my tune, but the offset volt vs. MS. was only like 6v-16v shouldn't their be some pulse widths within 2 volts before and after those at least?
Old 01-18-2019, 11:28 PM
ULTM8Z's Avatar
you really shouldn't be running less than 13.5 to 14.5V during normal operation unless there's a malfunction or something.
10 to 12V during engine start up...
Old 01-18-2019, 11:34 PM
Okay so majority of the time the volts are within that range and only rarely drop or increase? Or like you said unless of malfunction.
Old 01-21-2019, 11:25 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Yeah seriously, if u have a situation where voltage is < 12v, u shouldn’t or won’t be driving the car for long. I understand why GM does this, but for all practical purposes the 12-15v range is the most relevant for day to day operation.
Old 01-21-2019, 11:51 PM
Yeah but when the starter is actually running, the voltage can be MUCH lower than 12. Like 8 or 9 possibly. So it does matter for startup purposes.
GD
Old 01-22-2019, 07:56 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
GD
Good point GD. I should give that a quick check because of course the battery may not be at optimum charge either.
Eric-86sc
04-22-2019 08:36 AM
zman1969
01-11-2019 10:21 PM
Abubaca
Alternative Port EFI Intakes
37
12-20-2018 07:01 AM
92CamaroDE
12-14-2018 12:35 PM
89formula305tbi
10-24-2018 09:18 PM
Quick Reply: 32# Accel injector tuning
