Help with tunerpro
Car: 90 iroc z
Engine: 358 tpi
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with tunerpro
Correct, the values when changed will be red. After you do the paste save the .bin
Engine: Lb9
Transmission: M20
There is a flag table for code 32 and vats.
Disable them there.
As for the egr to disable it there is a manifold air temperate setting mat vs egr. You need to max this value.
Disable them there.
Engine: Lb9
Transmission: M20
If you have trouble finding something there is a parameter finder in the tool bar.
