Cheap Remote PROM solution
Old Jun 17, 2019 | 10:34 AM
aseychell's Avatar
Car: 1988 Trans AM GTA
Axle/Gears: 9-Bolt 3.27
Wanted to share with you guys what I did to be able to swap PROMS without leaving the ECM hanging from under the dash.
Very simple. Just a few cuts to the ECM chassis with a hacksaw, a Moates G1 (I had a JET one which is the same), a Moates Extender cable and a Moates Chip Extender.
Now I can mount the ECM back in its original location and just have the extender board out. If I want to take the extra mile, I can also remove the DIN chip carried and solder a ZIF socket but anyway I dont fiddle around that much with tunes once I got the right one.
Ribbon cable passing under one of the main connectors
Ribbon cable passing under the PCB
Finished Product
Old Jun 18, 2019 | 12:37 AM
GeneralDisorder's Avatar
Re: Cheap Remote PROM solution
You best wrap that in tin foil. The chips signals are very low voltage and are susceptible to EMI/RFI. I have had problems with the AutoPROM and ribbon cable interference.
GD
Old Jun 18, 2019 | 02:01 AM
aseychell's Avatar
You mean the ribbon cable? I think it should be grounded also no?
Old Jun 18, 2019 | 10:02 AM
I just wrapped in tin foil. I didn't ground the foil. Worked fine for me - stopped it from randomly stalling when the interference got bad.
GD
Old Jun 20, 2019 | 08:38 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That Chip Extender has virtually zero issues with EMI, except around very, very strong signals. Those chips on a PCB are signal amplifiers, which combat any interference.
Old Jun 20, 2019 | 10:47 PM
ULTM8Z's Avatar
Does this come with the ribbon cable?
http://www.moates.net/chip-extender-....html?cPath=26
Old Jun 20, 2019 | 11:37 PM
aseychell's Avatar
@sixshooter. That is actually my reasoning for using that board instead of a simple chip carrier. Anyways if I see strange behavior I will put some grounded aluminum foil. Thanks
Re parts you will need 1x CHIPEXT ( the board) and 1x EMUC2818 (the cable)
Old Jun 27, 2019 | 10:27 AM
That's good to know! I definitely had problems with the AutoProm ribbon cable that were solved with the tin-foil. I guess it doesn't have as much signal amplification?
GD
Old Jun 27, 2019 | 03:02 PM
aseychell's Avatar
Well to be honest I still followed General Disorder advise and covered it in tin foil + pinched part of it to the ECM body making sure there is continuity to ground.
ghettocruiser
Jan 25, 2017 09:06 PM
LittleNo
Oct 23, 2006 10:19 AM
seanof30306
Dec 12, 2005 08:32 PM
