Shouldn't I be seeing a reduction of SA
Old Jun 25, 2019 | 05:46 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
So I have been chasing knock retard that appears to happen at a very specific rpm/map range. I have attached a jpg showing an instance where knock retard is occurring but SA however is not being reduced even tho the log shows that KR is being invoked. Someone want to explain?
Old Jun 26, 2019 | 09:49 PM
ULTM8Z's Avatar
Re: Shouldn't I be seeing a reduction of SA
I know in 8D, there's a table that limits how much timing the ECM can pull. Perhaps the analogous table in your calibration accidentally got zeroed out?
Old Jun 26, 2019 | 10:31 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I know I have reduced that table but not zeroed out because I wanted some level of protection. The stock table is a bit overboard. But I guess my question is that of it shows that the ECM is retarding timing by say 2* why am I not seeing the resultant SA showing up in the log. When it starts to pull timing, shouldn’t the SA be the net of the KR?
Old Jun 27, 2019 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There isn't enough retard to easily see the SA reduction. It looks like the line right before the yellow area is at 15.52°, the next line being 15.47°.
The MAP is decreasing and the RPM is increasing, both of which will typically have a higher SA.
Then with the spark loop running at 80 times a second, and the laptop data logging at 7 times a second. It is easy for the SA value and the retard value to be mis-synced.
RBob.
Old Jun 27, 2019 | 10:01 AM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Thanks RBob. I will check further down the log to see if there is any evidence of retard altho it sounds like it may be missed by the logging rate vs spark loop rate. It looks minimal in any case. Dropping SA definitely has an effect on the KC/KR I log.
Again, it appears to be pretty specific as to the rpm/map region of the SA table. I’m a bit puzzled that I need to drop SA in this area only that at some points is actually below stock SA.
Old Jul 7, 2019 | 05:50 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
In addition to what RBob said, could there be higher SA values in your table at the RPM and MAP during the retard, than just prior to it. Might review that because don't see how it's possible for code to not reduce SA by retard amounts. Also, does your mask have spark coolant bias? If so, could there be a mismatch between the bias Scalar and the spark correction table value at the kPas reported during the reported retard?. For example, if the spark coolant .vs. MAP table value exceeds the Scalar bias value at a given Temp & MAP, SA would be increased by that difference before knock retard would be subtracted, making it look like SA not being reduced. Given the coolant bias delta is usually small and because your retard is small, one could be offsetting the other making it look like SA not reduced.
osirus
Jan 10, 2008 11:38 PM
85wilrocu
Oct 18, 2001 06:27 PM
matty350TPI
Sep 13, 2001 04:07 PM
TomP
Nov 20, 2000 11:58 AM
jms
Jul 28, 2000 10:33 AM
