PROBLEM FLUID WHERE IT SHOULDN'T BE!!!!!!!!!!!!
Old Sep 10, 2001 | 08:44 PM
matty350TPI's Avatar
Ok I felt something weird today when I was driving to work. On the way home I went home with no radio and all sounded well except shifting gears was kinda loud, there is always been a click from the gearbox when moving around the shifter from gear to gear, but for some reason it seems louder today. I got down and looked under the car and there seemed to be fluid on the floor pan behind the transmission. COuld the excessive noise be due to fluid lose in the tranny? Can I loose fluid out of the tranny? HELP!!!!!!!!!!! Hopefully I'll get a better look tomorrow.
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch, Spohn Sub-frames, Jamex 1.5 Lowering springs, 2 1/2' Exhaust,ram air setup
Old Sep 12, 2001 | 05:52 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
First of all, can you tell where the fluid is coming from? Speedometer drive/VSS? Tailshaft seal? Vent tube? Somewhere else?
If you suspect a decent amount of fluid has leaked out, get the vehicle up in the air, pull the fill plug on the transmission and check the fluid level.
But thy to let us know exactly where it is leaking from, so we can help you out.
Jed
89 Formula 350/T56 6 speed
Old Sep 13, 2001 | 04:07 PM
Ok got under the car the other day, and looked around, and it appears that it is just the fluid leaking out of the pinion shaft seal on the differential which I knew was leaking, now I took a good look with at the tranny and it lookes basically dry everywhere, driveshaft hasn't a spot of fluid on it same as where the driveshaft is inserted into the othput shaft so I cannot suspect the tranny of leaking. So I'm guessing that it is just the fluid travelling farther away from the differential.
92camaroJoe
Jul 29, 2023 07:57 PM
someone972
Aug 30, 2015 12:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
hokis
Aug 9, 2015 03:57 PM
