Adding a cat
Old Aug 21, 2020 | 10:44 AM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Adding a cat
Planning on adding a cat in place of a straight pipe when I first bought the car. Have kept the same tune for quite sometime. Can’t really mess with tuning right now since my newborn. My nb o2 is in driver side header. No wide band as of now. My guess is no but wanted to make sure and plan this later down the road if need be. Thanks for any help!
Old Aug 21, 2020 | 11:17 AM
ULTM8Z's Avatar
Re: Adding a cat
I'm not sure what your question is....
Tuning? WB02?
Old Aug 21, 2020 | 11:56 AM
maks10's Avatar
Car: 1990 Trans Am
Re: Adding a cat
Sorry does adding a cat pass the 02 affect the air/fuel readings? My guess is no but wasn’t sure. Thanks for feedback!
Hsr tune already established. Was hoping to not redo any tuning until I had more time. Btw thank you for all your hsr posts! Learned a bunch through the years with your tuning info! You helped solve my lean throttle tip in as well as others.
Old Aug 21, 2020 | 12:23 PM
ULTM8Z's Avatar
Re: Adding a cat
As long as the O2 is ahead of the cat you should be fine.
Old Aug 21, 2020 | 12:44 PM
maks10's Avatar
Car: 1990 Trans Am
Re: Adding a cat
Thanks!
Jix01
Jun 28, 2008 03:06 AM
usamuscle892
Jun 11, 2008 09:10 AM
fattie92
Jul 3, 2002 12:19 PM
Greg Kuhlmann
Mar 17, 2002 10:48 AM
Greg Kuhlmann
Feb 27, 2002 01:39 PM
