Offset compensation Bosch 0 280 150 943
Old Mar 26, 2021 | 05:20 AM
frebor72's Avatar
Hi
Anyone has values for Offset compensation vs Battery voltage and Short PW Compensation vs Pulse Width?
And injector constant if itīs not 19.50
Bosch 0 280 150 943
regards Fredrik
Old Mar 27, 2021 | 08:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Offset compensation Bosch 0 280 150 943
Are these the fat Bosch yellow tops?
RBob.
Old Mar 28, 2021 | 02:15 AM
frebor72's Avatar
Yes. That’s correct!
Car’s running rich in open loop. Especially during cranking
Old Mar 28, 2021 | 08:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
OK, these values should match.
Minimum PW @ 42 psi: 0.886
Offset Compensation versus Battery Voltage:
6.4 Volts: 3197 usec
8.0 Volts: 1925 usec
9.6 Volts: 1358 usec
11.2 Volts: 1029 usec
12.8 Volts: 795 usec
14.4 Volts: 633 usec
15.0 Volts: 574 usec*
Flow rate: 20.0 #/hr
RBob.
Old Mar 28, 2021 | 10:18 AM
frebor72's Avatar
Thanks!
Old Mar 31, 2021 | 02:45 PM
frebor72's Avatar
I use TunerPro and $6E XDF but I canīt find a Scalar for Minimum PW. Where can I change that value?
Old Mar 31, 2021 | 02:50 PM
frebor72's Avatar
Or is it Minimum Enrich Async Pulse Width? Current value 1.69 mSec
In $58A there is a value called Minimum Base Pulse Width. But I donīt find that in $6E. Only the one above
Old Apr 1, 2021 | 05:07 AM
frebor72's Avatar
I just found an Extended 6E here Expanded 6E definition file for Tunerpro - Page 2 - Third Generation F-Body Message Boards
This xdf has a scalar for Min Base PW.
Is this safe to use?
antman89iroc
Sep 21, 2014 08:49 AM
YenkoST
Mar 21, 2013 08:32 PM
ChainHartMachin
Nov 12, 2010 04:23 PM
95 4x4
Nov 10, 2008 06:41 PM
