Prom Reprogramming
Engine: 87 5.0L TPI
Prom Reprogramming
I am new to the programming so this question might be off the wall. I have a Memcal ADRR 3153 that came in a 7730 computer. I plan on using an AXYD for my 83 Z28 with a 87 305 TPI converted to 90-92 speed density. Is it possible to reprogram the ADRR and burn the data for a spare AXYD? Thanks in advance
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Prom Reprogramming
You can use the 2.8l memcal but must install a cylinder select jumper 56-62 pins on memcal and disable knock function.
89irocz355
Jul 15, 2013 07:21 PM
89irocz355
Mar 23, 2012 01:09 AM
