Tunerpro Question
Tunerpro Question
Is there any way to keep individual parameter editor windows open after you hit save in it?
When you make a change and hit save in the editor window, the editor window closes down and then you have to go back and reopen it. It'd be nice if it stayed open so you can make a follow up change quickly without having to go find it again the parameter list to reopen it.
In the preferences, there's an option for "keep editors open after update", but even though the box is checked, the editors still close down.
Also is there a way to make the text size bigger?
Car: check
Engine: check
Transmission: check
Re: Tunerpro Question
There are several ways to do this. A lower screen resolution does it. Also, under display properties, can make the fonts size larger.
RBob.
RBob.
