CobraRTP MotronicRT R6?
Does anyone have any experience yet with the CobraRTP MotronicRT R6 emulators? I see BoostedNW started selling them recently, and markets it as a replacement for the Ostrich now that Moates is out of business. Was curious if anyone's used one yet and what they think. Have a 1228746 ECM that I was planning on using it with, if it's worked well for others.
https://boostednw.com/motronicrt
Re: CobraRTP MotronicRT R6?
Oh, good to know. What's the difference in the 8746 that this won't work with it? Still just starting to dive in to prom & tuning; I vaguely remember seeing the 8746 isn't the best for tuning, but since it's all I have right now was hoping I could use an emulator with it.
What's the difference between the Pocket Romulator 1 and 2?
On another note - looking at BoostedNW's site, was a socket booster required for the Ostrich on 24-pin TBI applications like this? Made me wonder if they could eventually do a similar setup with the Motronic and a socket booster for 24-pin app's.
I reached out to Jamie at BoostedNW (US distributor for the Motronic) and he was confident about using it with a G2 and emulating as another chip with offsets. Thoughts?
I still have plans to try this setup.. I have all the components I think I should need, but got a bit busy with other things on the car so I haven't gotten around to it yet. Just need to solder in the adapter and do some testing once I get the car back together.
I finally got around to a test run, and so far so good. I haven't had a chance to test vss etc, as I don't have the transmission back in yet. But so far it functions well with offsets, similar to using an Ostrich.
Won't work in the '8746 ECM...
