Base Timing Benefits?
Old Apr 29, 2024 | 11:28 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
Now, my car is schiptuned and I would adjust the base timing in the chip as well, but is there any benefit to advancing the timing more than the stock 6*? Maybe for a little quicker response or something like that? I'm swapping the intake manifold soon to an edelbrock base so I'll have the dizzy out anyway, so I was looking for opinions on if it matters at all. Again, I would change the chip to match the base timing at the motor still, so my tune would still be accurate. Does it matter? My initial thought is no, so don't bother, but the more I think about it the more I think to myself that if the dizzy has to do less work to adjust the timing, then it'll start easier and the throttle could be a smidge snappier.
Old Apr 30, 2024 | 01:06 PM
???'s Avatar
Re: Base Timing Benefits?
other guys that know better will chime in, but from what I remember. the ecm take over timing at like 400 rpms or so. so the base would change your cranking time and what it defaults to if the ecm goes into limp mode maybe. I've seen 6 and 8 in gm cars. I don't believe it matters unless yours having a issue with something. it does need to match the ecm base thou.
Old Apr 30, 2024 | 01:42 PM
???'s Avatar
Old Apr 30, 2024 | 01:46 PM
???'s Avatar
Old May 1, 2024 | 05:55 PM
Larry's Avatar
Car: 86 Corvette
On a stock engine probably no. If you have a cam with more overlap then more advance while cranking could be beneficial.
Old May 3, 2024 | 08:46 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
If you go over the stock 6 degrees mechanically (on MAF cars at least) it limits how much advance you can use even if you tell the computer that you raised the base timing since the computer won't go over 44 degrees total if I remember right. This may have changed for the speed density cars if they went to 8 degrees but I haven't messed with those. As far as hard cranking goes the stock starter kinda sucks anyway.
Old May 3, 2024 | 11:48 PM
I have a proform mini starter, not the stock one. I needed it to clear me headers and to adapt to the 163-tooth flywheel on my 355.
Old May 3, 2024 | 11:49 PM
I do have a comp 8-502-8 hyd roller cam. So maybe I should increase to 8 or 9 degrees?
Old May 4, 2024 | 10:45 AM
Larry's Avatar
Car: 86 Corvette
I set my base timing at 11 degrees with my hotcam 218/228, 10.25 CR. It starts instantly hot or cold. Any less and it cranks over a few times before starting. Any more and it tries to kick back against the starter when hot.
benbruce
Feb 8, 2019 01:34 PM
FireDemonSiC
Jun 9, 2012 01:10 AM
TPI-Formula350-
Mar 3, 2010 11:39 PM
irocdaddy
Jun 1, 2005 01:21 PM
dj haf
May 25, 2005 08:09 PM
