Adding a parameter to Tunerpro RT Operations List in ADX file
Old Apr 2, 2026 | 09:07 PM
ULTM8Z's Avatar
Not sure why, but none of the 8D adx files (the ones on Tunerpro.net, or the SAUJP) have a parameter that shows "A/C requested". It has "A/C clutch engaged" (when the ECM detects the 12V applied to the clutch), but not whether the ECM is getting the initial signal from the dash switch for the A/C.
Basically I want to hook up my Classic Auto Air system to the ECM so I can have the A/C clutch controlled by the ECM. Basically what Tim C did.
https://www.thirdgen.org/forums/diy-prom/792545-c-clutch-disable-s_aujpv5.html
Theoretically I can do it without seeing that parameter, but it'd be nice to see the ECM report whether its seeing the signal from dash switch.
From Tim C's thread, it looks like I need to get TP to see tied to 0x0031 b7 where 1=A/C clutch ON.
Old Apr 4, 2026 | 06:56 PM
ULTM8Z's Avatar
Re: Adding a parameter to Tunerpro RT Operations List in ADX file
Disregard. I was able to get it to work w/o having to see the A/C signal request.
Old Apr 6, 2026 | 01:45 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Sorry I'm late to the party...
First Look at the ANHT hac and search for "Serial", this area will be your 6th hit.
This is the ALDL data feed list.
From there scoll down until you see what you want to log that isn't defined. In this case $0031 bit 7
Note the number circled. SUBTRACT 1 FROM IT. This is the packet offset to be entered in the new ADX aquisition bitmask definition.
Enter the number (56-1 = 55) in the integer side of the packet offset. Fill out the rest as it is here OR as needed for any other parameter you find.
Look at other definitions above and below it for any simple help.
Under Operand at the bottom:
Bit 0 = 01
Bit 1 = 02
Bit 2 = 04
Bit 3 = 08
Bit 4 = 10
Bit 5 = 20
Bit 6 = 40
Bit 7 = 80
Old Apr 6, 2026 | 07:25 PM
ULTM8Z's Avatar
Sweet! Thanks Vanilla... I'll give this a shot.
S10K20
Nov 4, 2015 12:54 PM
Restrorob
Aug 7, 2014 12:00 PM
TraviZ
Sep 4, 2006 04:07 PM
bluechevy194
May 4, 2006 08:29 AM
