connecting AEM wideband to 1227730 for datalogging
Car: Mgb
Engine: 3.4L
Transmission: 4L60
Re: connecting AEM wideband to 1227730 for datalogging
no. Only part 1 and 2 hold the values. The part 1 and 2 had what appeared to be real values prior to changing them. Part 3,4 and 5 all have 0000000 prior to changing them.
Car: Mgb
Engine: 3.4L
Transmission: 4L60
Awesome. thanks for making this happen. I will test it once I get my data acquisition working. What packet offset do I use 0x16 or 0x20?
thanks
Ray
thanks
Ray
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Car: Mgb
Engine: 3.4L
Transmission: 4L60
Engine: LB9
Axle/Gears: 3.08
no it was not replacing blm.
it looked like a timer maybe runtime. The disassembly can tell you. OEM I think was 0065. Whatever that parameter is was replaced by 0076 I think. I’m on my phone but you can verify in the patch I made or the earlier posts you made that show.
fastline
Aug 15, 2009 12:45 PM
