winaldl cable construction help
Old Feb 13, 2002 | 09:42 PM
Buck268's Avatar
Hi. I am about as green as possible when it comes to PROM stufffs. Anyways - I am am interested in using winaldl basically fer diagnostics (for now..). I have a L03 (91 TBI 305), what should I do for R3???
Old Feb 13, 2002 | 10:35 PM
89camaroRSV6's Avatar
actually u can first try leaving it open and it should work ... if not use a 10 K for R3 and u should be just fine ... thats one of the cirtcuts that works 100%
tell me what happens though cos im curious... as i remember right the 92 RS my buddy has no pin E for this circuit to work ... but if u have pin E great go ahead and try...
(when i say a pin a connecter will be there in the place (not an open hole))
pin E = 160 baud u are building the circuit for
Old Feb 13, 2002 | 10:43 PM
Buck268's Avatar
and if no pin e, just dont worry about it?
Old Feb 14, 2002 | 01:00 AM
well its as simple as this ... ur pins A&B
A- gnd
B - mode select pin
and E is the Data pin ... if u dont have pin E ( metal piece in the E slot) then ur connector wont work its useless.....
then ur alternative would be to go to PIN M the PIN thats directly below A (which is 8192 baud)
(the 8192 is a whole lot faster which means more samples / second)
this has a different circuitry,... more complicated circuit and a different software....
so go out there and check if u have the E pin
Old Feb 14, 2002 | 03:56 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Some ALDL connectors have the 160 baud data in another pin and some transmit both 160 baud and 8192 baud on the same pin (but not at the same time).
Old Feb 14, 2002 | 09:34 AM
Buck268's Avatar
Well, I have an 'E' pin. For what thats worth...
Old Feb 14, 2002 | 02:37 PM
jonas ... ur version works cool... what about 8192 have u written something for that yet...(cos i dont think winALDL handles 8192)
and buck if u have pin E ... this circuit will work fine with WinALDL
Old Feb 14, 2002 | 03:26 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
No, I have not written anything for the 8192 baud.
Old Feb 14, 2002 | 04:34 PM
Camaro_hunter_d's Avatar
then thats one reason why that interface did not work then huh 89RS?... LOL
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
