93 Eprom
Old Feb 25, 2002 | 03:29 PM
91RAGZ's Avatar
93 Eprom
I AM HOPING SOMEONE CAN TELL ME IF THE EPROM IN MY 93 LT1(SERVICE # 16159278) IS A 27C256 OR WHAT???? CANT SEEM TO FIND THAT INFO ANYWHERE!!!I HAVE A POCKET PROGRAMMER ON THE WAY AND WOULD LIKE TO ORDER SOME SPARE CHIPS.
I MUST EXPRESS MY THANKS TO ALL THE GURUS OUT THERE FOR THE AWSOME INFO!!!! ESPECIALLY TRAX FOR THE INTRO, NOW IM HOOKED!
L8R DEAN.
Old Feb 25, 2002 | 09:38 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I do believe that ones a 27512
Got a BCC/ Mask ID number?
Old Feb 26, 2002 | 01:08 AM
Wilson's Avatar
93 LT1 use the 27C256 Eproms.
Old Feb 26, 2002 | 04:56 PM
91RAGZ's Avatar
DONT KNOW WHAT A BCC/MASK NUMBER IS. COULD YOU LET ME KNOW WHAT TO LOOK FOR?THE NUMBERS ON THE CHIP ARE BDLD 7063 ON THE WINDOW STICKER AND BELOW THAT
1608 9388
BLUP9307 980
SINGAPORE O683
ALSO WOULD THIS BE COMPATIBLE WITH THE 29C256 FLASH PROM?
THANKS DEAN
Old Feb 26, 2002 | 05:54 PM
Wilson's Avatar
All 93 LT1's used Memcals which housed 27C256 eproms. The 27C256 eprom is soldered into the Memcal so you will have to unsolder the stock eprom and and resolder a flash prom in there or install a ZIF socket so you can swap out the chips easier.
The BDLD is the type of program that is in your eprom. For my car I have the BDZL which is for the 93 A4 w/3.23 gears. I believe the BDLD is the M6 w/3.23 if im not mistaken.
Old Feb 26, 2002 | 06:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
1608 9388
BLUP9307 980
SINGAPORE O683
THANKS DEAN
BDLD is the BCC (Broadcast code) that also identifies your ecm as being a 16159278, and a mask of DA.
If your going to get into prom burning, I'd suggest you remember that info..
That ecm uses the 256 series of proms so you can use the 29..
Old Feb 26, 2002 | 09:18 PM
91RAGZ's Avatar
THANK YOU BOTH!!!!
I DID KNOW MY ECM # BUT I ONLY KNOW SOME OF THE BASICS. I APPRECIATE YOU TELLING ME WHAT THE BCC AND MASK ARE BUT HOWD YOU COME ACROSS THE INFO? I KNOW THE POINT IS SOMEWHAT MUTE BUT ID STILL LIKE TO KNOW WHERE TO LOOK FOR THE INFO, BEING **** AND ALL
THANKS AGAIN,
DEAN
Old Feb 26, 2002 | 09:51 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
THANK YOU BOTH!!!!
THANKS AGAIN,
DEAN
The www.tunercat.com site list some info, I happen to have a BCC book, and probably a couple dozen other sites, in time you'll gather where to look.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
the_nikfive
Aug 11, 2015 02:46 AM
Grim Reaper
16
Jun 14, 2002 05:20 AM
a73camaro
Feb 20, 2001 03:20 PM
doc
Feb 13, 2001 01:58 PM
