injector constant changing?
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
A friend and I are curious as to simply changing the injector constant from 22# to 32#(car now needs it) does the programming do anything (perhaps behind the seen)to pulse widths/duration or am I tagging it to say 32# for my reference in
the future for whatever reason?
Car: Death Mobile
Engine: 666 c.i.
As long as you HAVE injectors that deliver "roughly" 32# then the ECM properly compensates and all should be fine. You may have to do some "tweaking" for VE Tables, Acceleration/Pump Shot Tables, IAC/Idle, Deceleration/Fuel Cut-off, but that is normal. Heck, I found myself having to tweak all those and my engine is basically stock.
Car: Sexy
Engine: Stock
Transmission: Slipping
Glenn -
Did you keep a record of the stuff you changed as you changed it? I'd be curious to see someone's "journal" of their PROM experience if anyone has one.
thanks,Glenn. No I have no record keeping because my current
chip is from tpis and I would like to look into it ,but I have read they can be difficult to read because they"move things around"
quoted from Grumpy.
quoted from Grumpy.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
