2 Transistor Interface Problems
Old Mar 3, 2002 | 08:38 AM
ssbowtie1's Avatar
Hi everyone, well I built the 2 transistor aldl interface and did a continuity test and it seemed that the hardware was fine. I got 12 volts and ground from the fuse box. I got the data from pin M and I put a 10k ohm resistor between pin A and B. When I opened Craigs software version 8.45, it said that it was trying to get a connection but never did and in version 850b, there were just random numbers on the screen, but the data never started logging. Am I doing something wrong with the port configuration or with the software? I don't know what it could be. Any help is appreciated.
Old Mar 3, 2002 | 08:54 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Originally posted by Craig Moates
Please go into the defaults menu (8) and set things up for the 'Diagnostic Mode' instead of 'Offline Mode', and then select your proper ECM. Might have better luck.
Apologies if you've already tried this. If you have and it still isn't working, then I have more work to do apparently.
As posted by Craig in the software thread. cheers Bob
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
