Will I NEED a new chip?
Old Mar 6, 2002 | 06:56 PM
87transam5.7tpi's Avatar
I'm adding trick flow aluminum heads, headman headers, and porting/polishing the intake,plenum, and new SLP runners. will I need a new chip just for that stuff? and if so how much will I benifit from one? thanks!
Old Mar 6, 2002 | 07:17 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: Will I NEED a new chip?
You only need a new eprom if you wish to have your engine perform optimally. How much will you gain? Depends how "off" your current eprom is.
Instead of thinking "how much HP you will gain", you should think "how much HP you are throwing away" with a "less than optimal" eprom.
Read Tim's (Traxion) eprom burning intro to see what equipment/software you need. Once you have all the equipment then you are dealing strictly with "tuning" issues. The more effort you put into it, the better the results you will get. Buying an eprom from someone else MAY get you close, but generally will not get you an optimal eprom unless they are doing actual "hands on" testing (which none do).
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
