Need help tuning for heated O2 sensor...
Old Apr 9, 2002 | 07:48 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm getting a set of long tube headers very soon and I'm going to run a heated O2 sensor just in case. My van originally had a heated O2 sensor so the 3 wire harness is there.
I switched to a 1-wire because it would idle horribly if I let it sit to warm up. If I drove it, it seemed ok. But I think there is some issure where the O2 sensor is warm and the ECM is trying to go into closed loop.
Maybe I should try adjusting the closed/open loop timer? I don't want to jump right into this because the idle oscillates wildly from 800-1200 rpm...only with the heated sensor. AND it only does that if I let it sit and warm up. If I drive it then it seems fine.
Anyone with a 7747 have this kind of problem?..any ideas?
Old Apr 9, 2002 | 07:59 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes, you should "play" with the timers for "cold start, warm start and hot start". I find that my O2 sensor is ready for "closed loop" really soon on a hot restart - but I still like it to run for about 30 seconds.
Conversely, I found that I like a minimum of 180 seconds for "cold start" no matter how quick the O2 sensor is working. Part of GM's logic in the timers was to match the ecm entering "closed loop" when the cats are ready to "light". You can continue with this "approach" or develop your own (i.e. go into closed loop sooner, or later).
Old Apr 10, 2002 | 06:08 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I see there is also two values that have to do with O2 voltage and closed loop.
One is "Go into closed loop upper limit" and the other is "Go into closed loop lower limit".
I'm guessing that when the O2 sensor is cold it is reading .45 mv...right? And it starts swinging when it warms up? So once it crosses these values it goes into closed loop if the other things are already met?
Am I close?
Old Apr 10, 2002 | 06:58 PM
Car: Death Mobile
Engine: 666 c.i.
Your close. Those are the "cross count" boundaries the ECM needs to go over/under to ensure the mixture is "oscillating' properly between rich and lean.
But Iwouldn't play with those. They are more useful if you have Long Tube Headers with a regular O2 sensor which just can quite get warm enough.
I would work with the timer and the "minimum coolant temp". Also, there are temps to determine when to use "cold, warm and hot" start logic. Look at those.
Old Apr 10, 2002 | 07:07 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks Glenn!!
88fastgta
Nov 17, 2010 10:04 AM
Tbi-MAX
Nov 29, 2007 08:51 AM
mapmaker
Jul 7, 2006 04:40 PM
badgta
Oct 25, 2003 01:52 PM
86TpiTransAm
Jun 2, 2001 12:49 PM
