Turn siginal problems
Car: 85 Camaro SC
Engine: V6
Get this when I turn the turn signal to the left. The light dosent blink but when I turn it to the right it blinks. What is up with that?
And my tail light fuse keeps blowing when I turn my lights on where and what should I look to see if its in its propper place? Any help would be appreciated
And my tail light fuse keeps blowing when I turn my lights on where and what should I look to see if its in its propper place? Any help would be appreciated Last edited by 85SportCoupeto89RS; Apr 19, 2002 at 11:36 PM.
Car: 1986 Trans Am
Ground
It almost sounds like you have a direct ground on the side thats not working.Check the voltage at the tail lamps to see if you're getting power with just the lights on then move the turn signal to affected side and check voltage again.Could also be in the column on the turn signal cancelling cam(YUCK).I had probs. like this too...I had a direct short in mine..hope this helps.
db057
Aug 11, 2015 10:11 PM
