Fixed a few of my problems, but now theres a new one
Old Apr 21, 2002 | 11:31 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I fixed my blinkers and tail lights, but when I press my brake pedal the gauge lights light up. Does anyone have any idea on this? I've searched and have turned up nothing on this topic.
Old Apr 22, 2002 | 12:29 AM
2vmodular's Avatar
sounds like your brakelights are finding a ground path through your parking light circuit.
Old Apr 22, 2002 | 11:53 AM
1986redbird's Avatar
check all your brake light bulbs and make sure they are the two element style, if you put a single element bulb in where it does not belong the current will jump across the socket and power-up the other side of the system (i.e. parking lights, etc,etc,)
Old Apr 22, 2002 | 11:32 PM
Car: 85 Camaro SC
Engine: V6
Yep that fixed it. Had one single fillament light bulb in my pass brake light. Must have gotten mixed up when I put them into the utility closet. Thanks 1986redbird
Old Apr 22, 2002 | 11:58 PM
Car: 85 Camaro SC
Engine: V6
Oh since I am happy right now I finished making my horn contacts. It was easy project to do in 30 minutes, made it from some scrap steel that was 75 thousandths thick and cut out a flat J shape then grinded it till it was as wide as my broken conctact then put the bottom part in a vise and bent then did the same to the top part. I have a working horn at last, I can finally stop using the middle finger horn
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
