I don't really have to go through the firewall do I?
Old Apr 22, 2002 | 05:35 PM
Arawn's Avatar
Ok, while under my dash digging for a hole in the firewall to run wire through I had a brain storm. Instead of having my wire run through to splice in where the fan relay is, couldn't I just splice the wire right at the ECM? I found 2 green/white wires going into the ecm. there's 2 connectors on the ecm and each one has a green/white going to it. which one am I going to splice into?
Old Apr 23, 2002 | 04:08 PM
Arawn's Avatar
Ok. so can anyone tell me what the other dark green/white wire that goes to the ecm does? All I *REALLY* would like to know is if the fan relay wire comes back to the short or wide connector on the ecm. TIA
Old Apr 23, 2002 | 11:30 PM
Omar's Avatar
It should be the short plug. I believe it's the C1 wire.
Old Apr 24, 2002 | 04:04 PM
Arawn's Avatar
THANK YOU! I'll try it out this afternoon.
Old Apr 25, 2002 | 02:51 AM
Arawn's Avatar
I tried it. wrong one It was the longer connector. but the switch works beautifully though, so I'm happy.
Old Apr 25, 2002 | 04:17 PM
92RSB4C's Avatar
There's a hole for the hood release cable with a gromet around it. If you expand it, you could get a couple of wires through there.
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
TheExaminer
Aug 26, 2015 04:59 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
