85 iroc gauges nonworking
Old May 2, 2002 | 10:14 AM
pyro's Avatar
ok so the gauges in my '85 iroc are dead all except the speedo
the ten amp fuse keeps blowing every time i change it also when i turn on the dashboard lights the door open alarm goes off
so like any good car nut i rip the dashboard apart
no good I cant find anything noticable that may be wrong
no wires twisted together nothing hanging from wires they are all secure in the harneses this must be a common problem because there is another post with the same thing and no responses so I am sure one of you guys has had it happen to you if you could fill us in that would be very helpful
thanx
Old May 3, 2002 | 03:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've never personally had the problem (yet..) but, I can tell you all the gauges (except the cable driven speedo of course) are powered off the 10a GAUGES fuse.
If you give a look here
http://92b4crs.tripod.com/86wiring/dia-pics/11-7.jpg
(drag link up to the addy bar of your browser to view)
You'll see a few other item (depenig on engine code) that are also on that circuit aside from the gauges. One of these could be a culprit
Also, don't rule out a gauge being bad. If the fuse will not blow with the cluster out, remove the gauges and then install them one by one until the fuse does blow. Maybe not the most handy advice but, that's how I'd approach it..
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
