High Torque Switch
Old May 13, 2002 | 06:49 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
High Torque Switch
Anybody know how to tell if the High Torque Switch (HTS) is bad?
How does it work? Does GM still make them?
Matt
Old May 13, 2002 | 10:04 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Never heard of it,may have seen it,where is it located on the car?
Old May 14, 2002 | 06:27 PM
Matto'85TA's Avatar
It's inside the headlight motor right behind the access panel that has the three screws. Its where the wires go into the motor. It can be pryed out easily with a screw driver. As far as I know it controls the up/down motion and when to stop the motor.
It's only on '82-'86's.
Matt
Old May 14, 2002 | 08:15 PM
Nightcruzer's Avatar
Car: Trans Am
This should help some
https://www.thirdgen.org/techbb2/sho...&highlight=HTS
Old May 17, 2002 | 05:09 PM
Matto'85TA's Avatar
Thanks a lot for the help. I will try cleaning them. Where do I clean? Do I clean where the thing contacts the motor? Should the 2 contacts be touching the motor? Or should they not touch.
THis a link to my entire headlight problem, explained in full. Take a look, if you can to see if there is anything else wrong. It's long though.
https://www.thirdgen.org/techbb2/sho...hreadid=105788
Thanks again
Matt
GTAman
Mar 15, 2019 11:40 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Ducati900ss
Sep 2, 2015 09:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
TA8487
Aug 16, 2015 12:21 PM
