speedometer/odometer stopped working
Old May 15, 2002 | 03:53 AM
irocz_ca's Avatar
what could be the problem? broken cable, vss, or what? thanks for reply.
Old May 15, 2002 | 05:35 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If it is a broken cable it should trigger the SES light and throw a code 24. On cable driven units the VSS sender is in the speedometer head. If you have an electronic speedo the VSS sender is at the transmission tailshaft area on the drivers side. Either system should throw a code if inoperable. Aside from a broken cable the drive gear is a very common problem.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
