My power options stoped working...
Old Sep 11, 2000 | 12:25 PM
irace_z28's Avatar
Some of my power options no longer work; door locks, dome(courtesy) light, trunck switch, cigarette lighter, and map lights (on rear view mirror). I dunno what happened, but one day they ALL stoped working. I checked my fuses and found one blown. It was the courtesy light fuse (20 amp). When I replace it, EVERYTHING works again but then the fuse blows a minute later and sometimes it blows as soon as I make a connection. I kept changing it and after the 5th time, I left it alone. There was also a faint smell of something burning (electrical). I hope I didn't mess anything up. And I didn't see any smoke either. I need some help. Thanks.
cliff
1992 Z28
Old Sep 11, 2000 | 01:10 PM
JAY87GTA's Avatar
Try leaving the cigarette lighter out. Sometimes they short out or something can fall in and short the socket out. Had it happen to me once. Hope this helps.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Sep 11, 2000 | 04:03 PM
Johnny Ray's Avatar
I would tackle this problem by disconnecting everything that is on that fuse. Have plenty of fuses on hand and connect one item at a time and put another fuse in. If the fuse doesn't blow, reconnect another item and so on. After you blow the fuse the first time, you know what it is. Process of elimination is my only resource at times. Good luck in finding the problem, it might be easier than you think!
1992 Artic White Firebird
t-tops
dual exhaust
1997 Black Firebird
t-tops
Chrome 5 spokes
2000 Honeycomb taillights
dual exhaust
Vintageracer
Jan 10, 2020 05:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
