Dimmer switch...headlight switch... HELP
Old Sep 12, 2000 | 07:12 PM
B L A D E's Avatar
OK, The dimmer switch no longer works...my interiors are on full blast. I swapped switches, that didnt do it. Also, in order to drop my headlights, I have to turn both the parking lights and the headlights off, then turn the parking lights on, then off, THEN the headlights go down....whats with that!?
1986 Firebird 2.8 MPFI
Old Sep 13, 2000 | 02:00 PM
B L A D E's Avatar
Please?
Old Sep 13, 2000 | 03:20 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Do you really mean the "interior" lights, or are you referring to the the instrument cluster lights dimmer controlled by rotating the headlight switch ****?
Tim
Old Sep 13, 2000 | 03:35 PM
B L A D E's Avatar
The IC light dimmer..the one that rotates!
Old Sep 14, 2000 | 01:10 AM
If you already replaced the light switch, then there is a short somewhere. +12 volts is supplied to the cluster lights through the light switch and rheostat (variable resistor) in the light switch, so the cluster lights must be getting +12 volts from another part of the light circuit - if the cluster lights only turn on if the light switch is in the running light or head light positions. Has anything been modified, or repaired prior to the problems occuring?
Tim
Old Sep 14, 2000 | 02:15 PM
B L A D E's Avatar
Radio work was the last thing done prior to this whole mess...
Dkelz313
Apr 7, 2016 10:38 PM
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
luvofjah
Sep 3, 2015 07:08 PM
