can i use aftermarket guages with a computer?
Old May 15, 2002 | 10:49 PM
KiLLJ0Y
Guest
Posts: n/a
i am switching to TPI set up from carb(non computer, non emissions controlled) can i still use aftermarket guages with the new set up?
i have autometers... tach, speedo, temp, oil, fuel, battery.
or do i have to use the stock set up?
Old May 16, 2002 | 05:28 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Only problem might be the speedo. The ECM on TPI models looks for pulses from the VSS sender which on mechanical speedometers is located in the speedometer head. These pulses are sent to the VSS buffer module and then to the ECM. They control TCC lockup(auto trans only) and EGR operation. If the ECM and new setup is stock you will trigger an SES light without the VSS input.
thunder57
Nov 7, 2015 02:28 PM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
