Update on VATS....
Old Sep 16, 2000 | 10:55 AM
Bill91Z
Guest
Posts: n/a
Update on VATS....
OK, checked for the small 24 gauge wires and only ones I see are 2 white ones coming from the column (which I was previously told these are the right ones) which go to a clip, coming from the clip are two small wires, black/white, brown/white. Is this what I'm looking for? Did I find it? So I assume I wire the resistor across the striped wires and not the two white ones coming from the column. Thanks guys
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 16, 2000 | 11:41 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The wires from the resistor connector to the VATS module should be white / blk stripe and purple / white stripe, according to the shop manual.
Tim
Old Sep 16, 2000 | 12:01 PM
Bill91Z
Guest
Posts: n/a
Yeah they are, bad lighting, I thought it was brown, but it is purple and white. So I guess I have the right one...thanks Tim
-Bill
Boston Chapter
Old Sep 17, 2000 | 10:12 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, put your resistor across the striped wires. Why are you bypassing the VATS? Are you haveing staring trouble? If so, and the bypass fixes it, then that proves that all that is wrong is the lock cylinder or key (usually the cylinder though) and is easy to fix. VATS is a very effective anti-theft feature. I am believe so strongly that I am retrofitting it into my '87.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
If you live in Southeastern US, check us out!
South East Thirdgen
[This message has been edited by GMTech (edited September 17, 2000).]
Elephantismo
Feb 13, 2019 12:51 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
