Timing Adv wire Blk Brn is KILLING ME
Old May 17, 2002 | 11:10 AM
87IROC350HO's Avatar
3.5 months now trying to fix the car. It will start with brn/blk timing advance wire disconnected, mechanically advance timing *20 and runs ok...not great. Reset timing *6 plug brn/blk wire in and she just pulsates in idle and pops when attempting to give her gas. I've changed the ECM, ESC, PROM, MAF power burn off module, corrected loose wires, resoldered other wires...bottom line .... I think she advances way too much with brn / blk wire plugged in I'd kiss anyones *** that could provide the right solution.
Stan
Old May 30, 2002 | 04:44 PM
28 views and no responses...hmmm. FYI: It was the distributor itself
Stan
Old May 31, 2002 | 09:59 AM
Blue91''s Avatar
Did that cure the problem?
Old Jun 13, 2002 | 01:04 PM
Replacing the distributor gave me advnced timing but got code 33 with the stock prom and 32 and 42 with the aftermarket prom
Old Jun 18, 2002 | 09:42 AM
mtccl's Avatar
I'd replace the computer with a junk yard one. They are cheap (like $15.00) and lots of other cars are compatible with ours like the Astro van. Search the boards for numbers. Just to eliminate the computer as the culprit.
Old Jun 18, 2002 | 11:41 AM
1986redbird's Avatar
how are you basing your timing, from the harmonic ?? could it be the balancer has spun a little and is giving you false reading ?? something to check !!!!
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
