ATTN: Tim
Old Sep 23, 2000 | 01:34 AM
B L A D E's Avatar
ATTN: Tim
I asked about the instrument cluster lights earlier, in another post. I cant dim them with the dimmer... I KNOW they are getting 12V from another source... I just remembered, I have two wires spliced behind the radio.. so I have SOME light.... without it, I have none... I replaced the roller switch, still no lights...where should I look now?
Old Sep 24, 2000 | 02:17 AM
B L A D E's Avatar
Help?
Old Sep 24, 2000 | 04:06 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It is possible to cause that type of problem by hooking up the radio to the harness incorrectly. If the radio feeds 12 volts to the gray harness (instrument lights) wire, the cluster lights will not dim. Disconnect the gray wire coming from the harness to the radio & see what happens. Maybe you hooked the gray harness wire to the amp on sense output wire from the radio or the electric antenna output wire from the radio.
Tim
Old Sep 24, 2000 | 05:13 PM
B L A D E's Avatar
Tim, I did that purposly... otherwise, I have NO IC lighting... so I had no choice... when I disconnect it, I have no lights... so they arent getting power... where should I look?
Old Sep 26, 2000 | 12:14 AM
The IC lights get power from the headlight switch through the 5 amp inst fuse, so of there is power at both sides of the fuse, with the parking lights on & the dimmer to full bright, the problem is between the fuse & the IC lights (gray wire). If there is only power at one side of the fuse, then the fuse is blown & there is a short some where down stream of the fuse that caused it to blow. If there is no power at either side of the fuse with the parking lights on & the dimmer to full bright, then the problem is in the light switch, or the wire from the light switch to the inst fuse (dark green).
Tim
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
ausrs
Jul 4, 2001 10:06 AM
