Alarm system questions
Old Sep 29, 2000 | 11:20 AM
AAustin50's Avatar
I haven't played with the alarm system on my car since I bought it last spring, mainly because the seller didn't give me the remote and I forgot to ask for it, and I've been too busy tinkering on other things. I did disconnect the alarm horn, temporarily, to prevent it from going off until I get a remote.
My (dumb) question: where does one normally mount the alarm electronics? I assume it's buried up underneath the dash somewhere? There is a toggle switch under the dash for disabling the system, and an LED, so I guess I just need to follow that back to the alarm box? Also, if I'm unable to get the original remote from the previous owner, will the manufacturer sell you a replacement? Do I need to open up the alarm box, once I find it, to get serial numbers as proof that it belongs to me?
Old Sep 29, 2000 | 01:20 PM
GndPrx's Avatar
This will really depend on the exact brand and model of alarm that is installed.
Some remotes can be programmed by a series of flips on the switch followed by a key sequence on the remote iteself. (learning remote)
Others require scratching off of certian wire traces on the circuit board of the remote. (sort of like a combination, some on, some off...scratch off remote)
You will have to find the brain which is "normally" burried up under the dash somewhere. A good installer will find a place that is hard to reach without taking down body panels, a bad installer will just drop the brain to the easiest access panel. Once you find it, get the make and model number off of it and either find a local retailer that carries that brand or call the manufacturer about getting a replacement remote.
Hope this helps.
GndPrx
http://www.caraudioresources.net
Old Sep 29, 2000 | 06:36 PM
AAustin50's Avatar
Going to take a look for it tomorrow GndPrx. Got in touch with the original owner tonight and he "thinks" he still has the remote and will ship it to me. He said it's a Viper alarm system, which I hear are very good? Found all the manuals (.pdf), etc. at their web site which I'm sure will come in handy.
MustangBeater20
Oct 29, 2022 09:20 PM
Stauf
Aug 24, 2015 08:31 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
