Help with rear deck lid
Old Sep 29, 2000 | 09:11 PM
88ROC's Avatar
Hello fellow 3rd gen owners.i have a 88 I-ROC with a electronic rear deck lid.The motor will not come up.the button up front works to release it,but the motor stays down.SO i now have a decK lid that of course won't shut.Need a direction to go in diagnoseing this..I see a relay back there behind the panel,but I don't know what wires to probe,or what to look for.Motor??...relay??/..or is it that contact strip under the deck lid itself.
I thank you for your time,and hope to be back on the road this weekend :>)
Old Sep 29, 2000 | 10:29 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
my first guess would be either dead motor (do you hear any noise coming from it when activated?) or bad relay.
another obvious question, is do you have any loose wires in there?
the hatch releases you said, so the solenoid has power and means your motor should also have power.
when you have the hatch up, stand back there and put your finger into the slot as pictured here...the slot i'm referring to has a switch in it for telling the motor if the hatch is in or out of position...
now, when you put your finger in here does it make ANY noise whatsoever???
get back to me w/these answers and we'll work from there
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Apr 14, 2017 05:37 PM
LittleFranks
Sep 17, 2015 12:22 PM
zayne0
Aug 24, 2015 07:22 PM
