How does this hookup (fuel pressure guage)
Old Oct 1, 2000 | 03:32 PM
Stell1579's Avatar
i ordered the autometer electronic fuel pressure guage (0-100psi) from summit.
now its part number ATM-3309.
anyone that got this already, does it connect inline w/ fuel lines? or on the fitting for the schrader valve????
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch
And Always Trying To Go Faster
Old Oct 2, 2000 | 08:56 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The sender connects to the 1/4" flare fitting at the rear of the pass side fuel rail. You will need to remove the schrader valve, first. Before you remove the valve, crack the gas cap open to relieve the pressure in the tank, and if possible, remove the valve when the motor is cold.
Tim
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
