Installing the delay windshield wipers
Old Sep 29, 2000 | 01:00 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Has any one replace there std. wipers with the delay ones? I know a new wiper motor and the new delay wiper switch will be needed, but is there anything else like a delay box or something? Will it wire up easily or does it require an entirely different wiring harness? Thanks
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited September 28, 2000).]
Old Sep 29, 2000 | 08:24 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The electronic delay module is actually in the wiper motor housing, under the removable black plastic cover. The switch assembly that goes with the delay wiper setup has a potentiometer (variable resistor) built into it to vary the delay cycle time.
Tim
Old Sep 29, 2000 | 11:35 PM
So, if i got the correct wiper switch and a new motor with the delay in the housing, would it work, or would some rewiring have to be done? thanks
-Justin-
Old Oct 2, 2000 | 08:20 AM
No rewiring should be required. Both the delay and non-delay setups use 4 wires between the switch & the control module under the hood - pink, purple, dark green & gray.
Tim
Old Oct 5, 2000 | 01:50 AM
Ok, Thanks. I'm going to order the new switch and get the motor and give it a try. If successful, i'll post a tech article on the conversion process.
-Justin-
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
