Fog Light Relay
Old Oct 7, 2000 | 05:51 PM
valu8or's Avatar
Fog Light Relay
What exactly is the fog light relay used for. It appears to me it is only used to shut of the fog lights when the brights are on. Is this true? Can I just connect the two brown wires from the relay connector together? The fog lights stay on when the brights are on. Does anyone know of any problems with this?
1986 IROC
New Crate 350 w/Vortec Heads, Edelbrock 2116 Vortec Manifold, Edelbrock Performer 2102 Cam, Edelbrock 1406 carb, Hedman shorty headers, Flowmaster Catback, Rebuilt 700r4 w/vette servo, etc..
Old Oct 8, 2000 | 07:36 PM
valu8or's Avatar
BTT
Old Oct 9, 2000 | 08:48 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Yes, you are correct. The purpose of the fog light relay is to turn off the fog lights when the high beams are turned on. Since the relay coil is off when the high beams are turned on [there is 12 volts at both the high beam (green) wire & the running lights (pin 5 brown) wire], either the relay contacts are stuck in the closed position, or the high beams are not being energized. Here's where the wires go:
Pin 5 brown: From running light circuit. Connects to relay coil.
Pin 2 green: From high beam circuit. Connects to relay coil.
Pin 4 rust fusible link: From red wire battery power. Connects to relay pole contact.
Pin 1 brown: To fog light switch. Connects to relay N.O. contact.
Tim
Old Oct 9, 2000 | 12:19 PM
valu8or's Avatar
Thanks Tim. I just connected the two brown wires together, the relay seemes to be bad and heavily corroded.
Old Oct 10, 2000 | 01:20 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
to answer your last question if anyone knows of a problem with this...
you should check w/local authorities about the legality of having fog lights on at SAME time as your high beams.
an initial guess here is that you might be a 'bad boy' if you do this.
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Oct 10, 2000 | 07:58 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Why would anyone want fog lights on concurrently with high beams? They're self-defeating.
Willie
Old Jun 13, 2013 | 03:20 PM
RumbleBee28's Avatar
Car: 1985 Z28 Black w/ Yellow Stripes
Engine: 383 Stroker
Transmission: Corvette 700r4
Axle/Gears: Stock
Re: Fog Light Relay
holy hell, this is exactly what I was looking for. So the plug that comes from the relay with the green wire and the brown wire goes to the running light/brown (parking light) and to the high beam/green?
This is the thread I created. I even posted a pic.
https://www.thirdgen.org/forums/elec...og-lights.html
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
