ignition module
Old Oct 20, 2000 | 07:12 PM
romani's Avatar
ignition module
what are the signs off a bad ignition module 88 iroc tpi ,remote coil ,accel 3oo
Old Dec 28, 2002 | 10:34 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Your car doesn't start, thats the deal with mine.
Old Dec 29, 2002 | 01:40 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...gnition+module
Old Dec 29, 2002 | 08:12 PM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
My ignition module just quit about three days ago. My car would not start and I had no spark and the fuel injectors were not spraying. The ignition module directly affects both fuel and spark because the computer needs the signal (motor speed) from the ignition module to know how much fuel to give the motor.
Old Jan 2, 2003 | 03:02 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
hhhmm... would a faulty igintion module cause the car to stall while driving on the interstate then not start for about 10 minutes then start and fun fine for a while until i have to repeat the process?
Old Jan 2, 2003 | 03:12 PM
88TAJeff's Avatar
Car: 88 T/A
Yes, the module gets hot, shuts down, cools and is fine again until it gets hot.
Old Jan 2, 2003 | 06:55 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you can take it to napa and have it tested
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
