Where's my Horn???
Old Oct 21, 2000 | 06:15 PM
Wolfcoast's Avatar
Where's my Horn???
Well I was troubleshooting the horn. I need it to get a base sticker (military)...
When I pulled the cover off on the steering wheel, guess what I found??
NO HORN SWITCH!! The stupid horn cap was glued on.. Also, there are no wires extending out through the steering column...
Here's my Q?
Anyone have an idea what exactly I'm missing. Looks like just the switch.
Hopefully the wires are just pushed down into the column.
I looked in my Chilton's and it doesn't really talk about the horn at all.
Info: 84 Z28, L69 5spd. tilt steering.
Thanx
Randy
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Oct 22, 2000 | 01:05 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
If you put that down as item #1 on your list, we'll knock it out! Does the horn have to work from the steering column or anywhere?
I didn't get inspected for my base sticker
Old Oct 22, 2000 | 03:21 AM
Wolfcoast's Avatar
Well I've figured out that there shouldn't be any wires sticking out. The wires are connected to the horn button. hehehe
But I've got a 90's Pontiac steering wheel just sitting here. (Sold the TA, never put it in)
I'll try & use that one and see if it works.
Randy
Old Oct 22, 2000 | 06:29 PM
Wolfcoast's Avatar
Well, new steering wheel is in and the horn works just fine.
Hey Duffster, thanx for all your help.. got 8 things on my list of 28 things to do, done today hehehehe.
Now I need to get off my but and finish the seats. Still waiting for the hog rings to get here.
Randy
Old Oct 23, 2000 | 01:01 PM
Duffster's Avatar
what are the other 20 things? ? ?
Old Oct 23, 2000 | 04:39 PM
Wolfcoast's Avatar
Duffster,
Just a few things...
1. Fix clutch (bleed slave cylinder)
2. Install rear hatch pulldown motor
3. Fix power seat DONE
4. Find leak on rear hatch DONE
5. Replace valve cover gaskets
6. Fix power door locks DONE
7. Install New steering wheel DONE
8. Fix horn DONE
9. Reupholster seats
10. Get new headliner
11. Recover Sun visors
12. Install new shift **** DONE
13. Install fuel filter
14. Install new ESC module DONE
15. Install new Shifter boot
16. Finish wiring stereo/amp DONE
17. Fix power mirror switch
18. Fix power hatch release DONE
19. Fix T-top seals
20. Clean engine compartment
21. Install Battery kill switch
22. Install Car alarm
23. Finish door panels
24. Convert to R134A freon
25. Install 145 speedo cluster
26. Install cupholders
27. New rear hatch cover for pulldown
28. Fix left turn signal
Some of these I'm waiting for parts on... heheheh
Got the stereo done today. Just need new front speakers.
Randy
[This message has been edited by Wolfcoast (edited October 23, 2000).]
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
