frigging cooling fans!!
Old Oct 23, 2000 | 06:52 PM
cursedz28's Avatar
Ive had the same problem for a year now. I about gave up on it and hooked a fan up to the ignition. I got two fans right. Can sombody tell me the actual way they are supposed to run. Every shop has a diffirent story. The fan on the driverside I thouht was supposed to go on with the A/C. Thats all I know.
Old Oct 23, 2000 | 07:23 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The factory fan function varied by year. What year and what engine?
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Oct 23, 2000 | 11:38 PM
cursedz28's Avatar
Sorry, Im stupid. ITs a 91 Z-28 305 tpi.
right now I just got the passenger side fan wired to the ignition. It has an ADS superchip. I think thats who makes it. Isnt that supposed to turn on the fan earlier?
Old Oct 24, 2000 | 08:17 AM
Willie's Avatar
Okay, here goes. The primary fan (driver's side) turns on when
1) Engine temp rises to 223 degrees or
2) A/C is engaged and vehicle speed is over ~35 mph or
3) The ALDL diagnostic terminal is grounded.
#1 & #2 are ECM controlled.
The secondary fan turns on when
1) Engine temp rises to ~243 degrees or
2) A/C is engaged and vehicle speed is over ~35 mph.
#1 is controlled by the fan switch located in the passenger side head. #2 is ECM controlled.
If your fan(s) are not engaging as specified, the only approach is to locate the problem and fix it BEFORE any changes are made.
Willie
12.57 @ 111 mph.
Old Oct 24, 2000 | 08:59 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Addendum to secondary fan #2:
The secondary fan turns on if the pressure on the A/C liquid line is above 232 psig (150 F for R-12). There is a pressure switch on the liquid line. The ECM monitors the status of the secondary cooling fan. The secondary fan should run on a very hot day with the A/C on.
Tim
Old Oct 24, 2000 | 09:15 AM
Stuart Moss's Avatar
Willie,
I think you meant to say "...and vehicle speed is under (vice over) ~35..." for both fans.
[This message has been edited by Stuart Moss (edited October 24, 2000).]
Old Oct 24, 2000 | 02:02 PM
Willie's Avatar
Originally posted by Stuart Moss:
Willie,
I think you meant to say "...and vehicle speed is under ~35..." for both fans.
Thanks Stewart. It was very early this morning when I posted -- the brain wasn't functioning yet.
Willie
[This message has been edited by Willie (edited October 24, 2000).]
Old Oct 24, 2000 | 07:51 PM
cursedz28's Avatar
So the driver side is the primary fan? Does my chip affect its turn on point? Last time I checked the motor was still good for the fan. She ran hot as hell today in the city.
Old Oct 25, 2000 | 07:54 AM
Yes, the driver's side is the primary fan & the on & off temperature thresholds are programmed in the PROM.
Tim
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
