burned, corroded harness!!!!!!!!
Old Oct 24, 2000 | 11:30 PM
spitfire350's Avatar
Hey,
I have an 87 camaro 350 (crate)and a t-5. and my question is, there are 2 small relay looking boxes that have wire harnesses pluged into them on the passenger side of the motor their between the battery and the coolant tank and their bolted to the inside of the fender. but the one closest to the battery has some serious corosion and burn damage that was crap riged with duct tape buy the previous owner. And i was wondering what this harness does and if i need to replace it. well thanx for any info.
keep the stang's far behind u and the cops even farther
Old Oct 25, 2000 | 08:16 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your motor is carbureted, the relays are for the throttle kicker (near the radiator), and the choke heater (near the fender).
Tim
Old Oct 25, 2000 | 12:50 PM
what exactly does the throttle kicker do and does gm make a new harness or would a junk yard be the best place to look?
thanx alot for the info
Old Oct 26, 2000 | 09:31 AM
The throttle kicker relay coil is controlled by the ECM. When the coil is disengaged, the relay contacts power the idle stop solenoid, and idle speed is increased. When the coil is engaged, the idle stop solenoid is only powered if the A/C is turned on, in which case, the idle speed is also increased. You may replace the GM relay and mating connector with a 30 ampere Bosch relay and a Bosch mating connector, which are available from most auto parts stores. Here's how to wire the new Bosch relay in place of the GM throttle kicker relay:
pink / black: relay terminal 85 (coil)
black: relay terminal 86 (coil)
light green: relay terminal 87 (NO contact)
pink / black: relay terminal 87A (NC contact)
dark blue: relay terminal 30 (pole contact)
There are two pink / black wires. The one that looses power when you remove the 10 ampere gauges fuse, with the ignitin on, goes to relay terminal 87A.
Tim
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
85 Jimmy
Sep 30, 2015 07:56 AM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:40 AM
