VATS Problem Question
Old Oct 26, 2000 | 09:24 AM
Mark W. Winning's Avatar
If you VATS is failing, what are the signs. My 92 Firebird used to not start once in a great moon, but now it acts up almost everyday. When the key is put to the start position, the gauges move, security light comes on, but no start. What else do I need to look for?
The car was a V6 and is not converted to a carb V8, but I used the stock cranking wire.
Mark
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Oct 26, 2000 | 09:55 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There are a number of posts on diagnosing problems with the VATS system. Do a search on "VATS" in the electronics section. If the security light comes on with ignition power & stays on, then it may be that the contacts in the ignition roller assembly that contact the resistor in the key are loose, or dirty, the resistor in the key is dirty, or there is an intermittant connection between the contacts in the roller assembly & the VATS module.
Tim
Glowsock
Jul 24, 2025 03:15 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
